820-02100 SSD REPLACEMENT
huzeafa
Hello guys.
Please I need help with a 16-inch 820-02100 board. The Board was working but would restart immediately after the OS started to load, it is the same thing when I try to press and hold down the power button to access recovery, I tried to restore the device in DFU MODE on multiple attempts, and I got error code suggesting a possible issue with the NAND, I then decided to replace the NANDS, this is not the first time I have replaced NANDS on this boards, I usually do a direct transfer from a similar board with similar NAND arrangements, for example, the board am currently working on, only has one side of the wing populated, hence I used a similar board. After installations, I am not able to restore the device, won't even go into DFU Mode, the MAG safe 3 cable connected keeps going on and off, as the device is circling, I thought might be the NAND, so I took a different set from a similar board, but the behavior remains the same.
huzeafa
Check diode mode on all secondary power supplies.
Do you get stable PPBUS_AON and 3V8_AON now?
I have a stable 3V8_AON. However, PPBUS goes high to 12.0V and then drops to 6V or so and quickly goes high to 12.0V. At the same time, I noticed PPDCIN goes up to 20V and then quickly circles down to 5V, which corresponds to when PPBUS circles down to about 6V.
I compared diode mode measurements on a working board and got about the same reading.
PLS NOTE: The above behavior is what I get without SSD on the board.
So am not sure how to tackle this.
huzeafa
is there something else I should do regarding the NAND REPLACEMENT? Should I get a different set of NANDS ?
If you got the NANDs from same model board and respect basic rules, it should work.
If not, bad solders, bad chips, something else affected on the board by heat...
