Hello out there.
I purchased this mac MacBook Pro 13'' M2 chip, model A2338, logic board number 820-02773 as partially working. Seller give me an apple report saying: "Liquid spill on trackpad flat, BMU battery flat and logic board. Macbook starts only when connected to DC IN and show intermittent shoutdown".
Now ,that I got, it is does not start at all, usb Amp mether shows 5V 0A on both usb-c. Connecting to the transformer adapter side (not logic board side) I can detect 5.237V and 0.034A.
Tearing down the logic board I can confirm there was liquid spill on the battery connector area and the battery flat. Liquid spill also on the trackpad connector and small amount on the antenna wifi connectors.
The back side of the board is pretty clean, no sings of corrosion or cleaning.
The fact is that this moderboard was already cleaned from moisture.
no components it's getting hot when plugged in.
Upon cheking, no low resistance found at each inductor / coil on the board.
PPBUS_AON
1 PPBUS_AON 12.3V
2 PPVIN_LCDBKLT_F 12.3V
PP3v8_AON
L5800
1 P3V8AON_VSW1 3.78V
2 PP3V8AON_PH1 3.78V
PPDCIN_AON_CHGR_R 5V on both ports
LDO outputs
PP3V3_UPC1_LDO 3.44V
PP1V5_UPC1_LDO_CORE 1.58V
PP3V3_UPC0_LDO 3.44V
PP1V5_UPC0_LDO_CORE 1.58V
CD3217 support voltages
CC270
PP5V_S2 0V
RG2A0
1 PP3V3_S2_LDO 0V
2 PP3V3_UF790 0.34V
PP3V3_S2_USBLS1_ISNS 0V
PP3V3_S2_WLBT_ISNS 0V
PP1V25_S2 0V
RC714
P3V3S2_PWR_EN 0V
P3V3S2_EN 0V
PPBUS_AON_3V3S2_VIN_ISNS 12.30V
LC260
1 P5VS2TPS_PHASE 0V
2 PP5V_S2 0V
P5VS2_PWR_EN_RC 0V
PP1V5_LDOINT_MPMU 1.48V
PP17V0_LDOIN 3.30V.
resistance to ground of PP3v3_S2.
CC717
pin1 PP3v3_S2 35 ( 2000K scale on multimeter) ohms
pin0 gnd 0 ohms
Upon cheking, no low resistance found at each inductor / coil on the board. Also attached in photos diode mode readings. Mine in red, black one as reference.
Sorry for boing noob as hell, I hope to learn something here.
I would be glad if somenone more skilled that me will help me troubleshotting this Mac to have it finally working. That would be really appreciated.
PPBUS_AON
1 PPBUS_AON 12.3V
PP3v8_AON
L5800
LDO outputs
CC270
PP5V_S2 0V
RG2A0
1 PP3V3_S2_LDO 0V
2 PP3V3_UF790 0.34V
PP1V25_S2 0V
RC714
P3V3S2_PWR_EN 0V
P3V3S2_EN 0V
LC260
1 P5VS2TPS_PHASE 0V
2 PP5V_S2 0V
P5VS2_PWR_EN_RC 0V
PP17V0_LDOIN 3.30V.
CC717
pin0 gnd 0 ohms
