820-2849 fans run at full speed when the battery is attached
kjchatman
the efi and OS diagnostics both passed. the only strange thing that i notice is that chgr_bgate is 0.9v and it charges really slow. u7000 has been replaced several times and q6910 was replaced
kjchatman
chgr_bgate is 8.3v when there is no battery and .9v with a battery. the fan runs normal without battery attached and it runs full speed with a battery
kjchatman
chgr_bgate_r is 8.3v with the battery disconnected and 0.9v with the battery connected
chgr_ovp_a is 0v with or without the battery
today i replaced the smc and the fan ramps up and is still loud with the battery attached
it still passes the diagnostics
Exact PPBUS_G3H voltage w/ and w/o battery connected?
Test the machine disconnecting BIL (J6995), with battery.
"Test the machine disconnecting BIL (J6995), with battery."
Still not working properly?
BTW, did you test with known good battery?
kjchatman
today i installed a new battery and the fan still ramps to the max speed but if the battery isn't connected then they run normal speed
Check current and voltage sensors, at pages 50/51; especially DCIN and BMON current.
Be sure R7050/51/52 and their traces are good.
