Then R7967 is bad.
If is good and has 3V on pin 1, same voltage must appear on pin 2, if there is no other component connected.
Or you forgot some power good resistor...
This board is still having a issue. Missing PPVCORE_GPU 0v
Q8950 has shorted a couple times since fixing the board. Once after replacing had 0.90V on PPVCORE_GPU but Q8950 shorted again when turning board back on afterwards.
Already replaced U8900 and checked the surrounding resistors. What should be checked?
4.20 0hm resistance to ground. Similar board is 7.6 ohm
Already replaced GPU with brand new known good GPU. While GPU was removed there was 1.2V-1.3V on L8920. When New GPU was installed went back to 0v-0.13V
