820-2915 no green light, works on battery after isoprophyl cleaning display connector
Crazyfrog
As title says I was having screen flickering issues so sprayed isoprophyl on the display connector, now theres no green light. Laptop works fine from battery power
I already went through a schematic and found R5311 to be only 67k but seems suspect as if the schematic is wrong(going to order. What should I be looking at next?
UPDATE: photos added and U7000 gets very hot its a bit small for me to resolder, any other causes for this? Forgot to mention I have a CMIzapper gpukilller fitted for sometime working fine.
Remove battery and test the board alone on the desk (only charger).
Do you get 3V42_G3H and PPBUS_G3H, with correct values?
Crazyfrog
Can't say on that I just found a short on c7000 and c7001 after removing both caps(and losing one) the pads are shorted to ground.
Also R7051 measuring 43.2ohms not the spec 2.2ohms.
Update saying that r7051, r7052 and c7050 all showing 43.2ohms
Sorry, I didn't see you've open the thread as new user.
Welcome to the forum!
Dead U7000, change it.
Also replace all damaged resistors with correct values.
Do NOT quote an entire post visible few centimeters above.
Please maintain forum aesthetic...
Crazyfrog
I didnt notice you were admin either, thanks took a while to activate ended up scrapping that last board.
Is there nothing else that can cause u7000 to heat up like that? I dont think I'm capable of getting that soldered back properly.
You must check diode mode to ground on PPBUS_G3H and all big coils.
It is only theory now, if you cannot replace U7000.
As no caps remain on pins 19/20, ISL5259 is the only reason to have short there...
Crazyfrog
Ok I replaced u7000 I get greenlight now but no charging and no red light. Power off battery still works and OSX says battery not charging but coconut battery shows charging at 19.12 watts(its not charging).
Crazyfrog
Ok changed Q7030 and Q7035 and both getting super hot.
Source links here cpc, rs online and other electronic suppliers dont seem to sell them in the UK i could only find ebay for single components in france with expensive post
I don't suspect the MOSFETs.
Check for knocked off, or moved components.
Be sure to have good solders and check all traces.
Pay atention to C7025.
Post basic voltages of U7000 and diode mode to ground at PPBUS_G3H.
