PhilipC
no liquid damage, just suddenly stopped according to customer
It will run fine on a genuine charger but after about 2 mins of unplugging the charger the machine will slow down with 100% cpu usage
System detects and charges the battery also info comes up in the about>more info
It passes EFI asd and OS asd throws up an error
Battery test (test#31) -Unconsumed Battery capacity test
ERROR -- 255 [Uknown result-code 0xff] -- TEST FAILED
This is a replacement battery as I thought the original battery was at fault and have since then thrown away the original battery.
Checked current sense resistors and r7005 all measure fine.
If I remove the battery and plug it back in it will start then after 5 seconds go off. After that it will start normally
And when it boots (charger plugged in) right at the end of the loading screen it glitches out then comes back and continues loading
