820-2936 Fan turn on and off cycling, no orange LED when connected to battery
protocold
tried to remove Q7550 and the pin 4 pad seems no short but when replaced another Q7550, the short come back.. is this a short?
protocold
Q7550 pin 4 is connected to U7400 pin 12, when both are on the board, they seems to be shorted to ground(9 ohm). L7550 = 0V when on power.
with Q7550 removed, the pin 4 solder pad have no short and when measure voltage it pulses.
CPU coils may have very low resistance to ground as normal.
You can compare eith good board.
I suppose you don't have any short there.
Did you try to start in SMC bypass mode?
Just in case, replace R7402 and check its traces and solder to pin 2/U7400.
protocold
R7402 is good and its traces and solder to pin 2/U7400 are good too.
SMC bypass mode = fan stay on, USB storage has LED on too.
What is CPU voltage after 10s?
Did you try more DDR3 memory modules?
If machines stays on in SMC bypass, then you have problems with a SMC sensor.
Check first AVREF_SMC voltage.
protocold
L7510/20 = 0.9v after 10s. L7550 = 0.44v at that time.
machine did stay on in SMC bypass, PP3V3_S5_AVREF_SMC = 3.3v even when the fan stopped spinning..
VCORE should drop around 0.75V when board really boots.
In SMC bypass the fan should spin continuosly to max speed.
Take a look at the circuitries from pages 49 & 50.
Your starting problem is related with one I/V sensor.
Check their output voltage in SMC bypass mode.
protocold
SMC_CPU_VSENSE = 0.65 - 0.95 fluctuate
SMC_CPU_ISENSE =0v
SMC_GFX_VSENSE = bouncing 0 - 0.7v
SMC_GFX_ISENSE = 0v
TP_SMC_P1V5S3_ISENSE = 0.27v
SMC_CPUVCCIO_ISENSE = 0v
TP_SMC_SA_ISENSE = unknown test point location
SMC_DCIN_VSENSE = 2.82v
SMC_DCIN_ISENSE = 2.1v and when lifting multimeter it will shut down
I will measure the rest later today but is anyone of the above look suspicious so far?
