820-2936 no backlight
You are confused somehow.
Pins 1, 2, 5, 6 are common for Q9706...
Please be sure about provided information.
"pin 1 12.60V pin 2 0V"
IMPOSSIBLE!!!
Pins 1 and 2 are common, as 5 and 6 too; all these (four) pins are directly connected inside the Q9706 package...
Please, look at the schematic.
"Do you have image?"
Post LCD_BKLT_EN, and voltage pins 2/3, 4, 6, 7 of J9000.
Measure always with LCD connected...
Kyle93
Is board un repairable then? Is it worth trying a new pch?
Vcore does start at 1.1V and then drop to 0.8
"Be sure no corrosion and good contacts at J9000.
Also test external video."
"pins 2/3... 3.2v"
Looks like screen is detected; you should also get image.
