820-3115-b - weird graphics problem
Anterweb
This came in for a service and ssd upgrade, customer said it was slow and kept hanging.
Board was filthy inside so put it through the ultrasonic added the new ssd and some ram but when installing os I noticed some weird graphic stuff going on, like blocks for a courser and then (see image) 20220514_194747.jpg
Looking through the forum I see a few posts relating to graphics on this model and numoros solutions..
Any advice on the best fix for this appreciated.
There is no dedicated graphics, just iGPU embedded into CPU.
You may have problems with CPU, or RAM.
Test the board with one RAM module at time.
Did you test external video?
You have the option to disable AMD GPU, if still note problems.
Unigine Heaven benchmark is very good for GPU stress test.
I recommend to disable GPU flashing the GMUX.
If you do it in BIOS, set EFI password; to avoid accidental PRAM reset.
BIOS mod isn't PRAM resistant.
Anterweb
"I recommend to disable GPU flashing the GMUX"
This is a new one on me, any guides on doing this anywhere as I'm keen to learn how,
Thanks for the info! Again ur a legend, I've learnt so much from you guys the last 2 months, much appreciated.
Anterweb
After doing my homework it appears that buying a Lattice HW-USBN to flash the GMUX is by far the easiest and fastest solution for these machines,
But is the file required to flash the GMUX something I can get here , Or would I have to pay for a license for it each time I have one of these I need to flash?
Anterweb
Dude, I'm finding serval different places to get this file, am I correct in thinking the one that seems easily available does work ok but after flashing you can no longer use the toggle brightness keys on the keyboard? also is there any other common bugs that occur after flashing the GMUX?
(I have ordered the lattice programmer and am just waiting for it to arrive )
Tiresias GPUKiller is the best.
It preserves keyboard controls for backlight.
GMUX flash, as BIOS mod too, don't allow backlight control.
Anterweb
Tiresias GPUKiller Looks like the perfect / easiest solution. sadly these Tiresias chips cost more than this model of mac is worth or sells for here in the UK!!! :eek:
Ill give the GMUX a bash when the programmer arrives!
Thanks dude
Flashing GMUX is the fastest way; no need to remove the MLB from its house.
BIOS mod takes time to desolder/resolder SPI chip and doesn't resist to PRAM reset.
Keyboard control is still active under old macOS versions; doesn't work since High Sierra.
Also need to force enable/adjust backlight signals, to avoid sleep/wake problems.
I didn't test the control for GMUX flash under El Capitan.
However, in both cases, software control can create a backlight adjust impression.
The perfect fix is Tiresias GPUKiller.
If I correctly remember, Harald makes good discount buying in bulk.
And he has many other interesting tools in his store.
piernov
Moderator
GMUX firmware mod can still do brightness adjustment with either PCH microvia jumper (software and keyboard control, soldering is risky to perform), raw keyboard signal (no software control, some jumpers required) or custom driver (software and keyboard control, no soldering required), depending on the custom firmware applied to GMUX.
Anterweb
This is fab info thanks so much, my programner is going to take a while to get here so is there any reccomnded sources for gaining the info and files required to carry out this GMUX flash while maintaining brightness control?
There must be a test point (the opposite board side I think), which avoid the risky solder onto PCH package.
Anterweb
So this arrived today!
My only current options are to try following one of the available YouTube videos, that's no problem it looks easy enough to attach this thing, but I can't for the love of god find the file I need to use to flash with, if you could help with pointing me in the right direction for getting this file that works with the brightness buttons and or any good info for doing this process I'd be very grateful, I might even send you some donuts! 😍
Anterweb
I've tried for 2 hours today to get my head round this without asking for help but I'm moments away from throwing it out the window!
I get the wires solderd on no problem, power up the macbook without the HD connected then get the light on the lattice go from red to green,
Power up the software that appears to see the device but just throws up that error each time.
And I can't for the love of God find anywhere within this software that I load up the file you gave me,
What am I doing wrong?
