820-3115 board slight water damage , no green light
turbo
3115-b board, ppbug3h is good 12.59v, PP3V42_G3H_REG= 3.4v
PP3V3_S5_REG=3.3v
no green light
SYS_ONEWIRE=3.4v on u6900
pls chk attach pic where was the water damage
pic 1 u5400 fixed...
turbo
No Title
update !!! i change the magsafe now turn on!!!!!!!!! but no post, the white led is on ... does not boot or chime, is this because of i took out u3890..... or something else??? pls chk attach pic
larossmann
U3890 will have nothing to do with this. What do you measure on CPU vcore? Check R7403 and R7402.
turbo
ton r7403 and r7402 is good L7520 and l7510 both haS = 1.12v
BUT L7550 NO VOLTAGE...
also is u5400 is related to turn on l7550?!
If VCORE doesn't drop from 1.12V to aprox 0.8V, no AXG voltage.
Check SPI chip area; traces, resistors.
Do you have 25MHz oscillation?
