820-3115 No image, on USB
iClub
No oxidation, no USB activity, cooler spins. Replaces u7400 and r7402,03, the CPUIMVP_TONA voltage 0.67V , I found too low.
Voltage: PPbus_g3h 12.59V; PP3V42_G3H 3.42v; ALL_SYS_PWRGD 3.3v; PLT_RESET_L 3.3v;PPVCORE_S0_CPU 0.87V.
Board doesn't boot with new file?
I just swapped Fsys area from the file you sent.
PCH heats on these boards, as doesn't have any heatsink...
iClub
when I test with the multimeter in the CPUIMVP_TONA mesh the mac turns on, strange. Replaces the u7400 and r7403/02, but still with the defect.
iClub
When I started to do the analysis it didn't show image and without activity in the USB, it replaces the u7400 and the resistors, I didn't have result. Then, replaces the u6100, the mac showed white screen, and was locked in the PRAM reset sound, after a certain time it did not give more image. I recorded the BIOS file you sent me and used another BIOS chip, but it didn't work.
iClub
The mac displays an image, but when I select MacOS, it freezes. And most of the time it doesn't give an image. Vcore 1.12V after a few seconds it drops to 0.87V. It looks like a RAM or CPU defect.
I tested with RAM 10600 and 12800 module.
"Vcore 1.12V after a few seconds it drops to 0.87V"
That is normal behaviour and I explained to you several times!
The drop voltage, means the board is booting.
However board can get stuck after few seconds; have to find a reason for that.
Did you reball SMC?
iClub
I changed the SMC, in the tests the board is with the same defect. In SMC it had a relief in one of the pads, so I replaced it.
