I have a Macbook Air 820 - 3437 - B
The Macbook has had issues booting but once I disconnect and reconnect the battery it's fine.
I has also had an issue where after shutdown, if you press the power button, it won't button unless you hold it in.
It has 'XYZ' percentage while plugged in, and once you disconnect the DC it can change, ie, from 75% plugged in to 69%.
Once you plug it back in it may go back to 'XYZ' percentage or stay where it's at. Very strange.
Custom says they have issues booting it all the time, however I do.
These are the only symptoms I can find - unsure of previous repairs, so is customer.
Thanks, Max!
Thanks, Max!
