ytesfay80
This board was damaged from coffee spill. Initially the only thing that would happen when the charger was plugged in was a light on the charger.
I wrote down the components that were damaged before fluxing and heating the areas.
q7130
c7621
removed u1950 and pad for 3v42 was gone. scraped a little and brought it back
u8160
replaced u5110
replaced c7137
removed corroded j6100 and cleaned pads
After cleaning those areas the fan turns on and CPU VCore is around 1.69v. I plugged in the trackpad cable, screen cable and ssd and I don't hear a chime nor do I see anything on the screen even with a flashlight. I have no voltage on backlight output.
SMBUS_SMC_0_S0_SCL - 0v
SMBUS_SMC_0_S0_SDA - 0v
PPBUS_G3H - 8.57v
U8300 (Pin 1 - EDP_PANEL_PWR) - 0v (I even plugged in a bare lcd with just the lcd cable plugged in and it was still 0v.)
There are no damaged components around the SMC but there are a few probe points that look like they took some liquid damage.
Also, the battery was kind of hard to pull out and it looks like it had some damage to it but I did all these measurements without the battery plugged in.
q7130
c7621
u8160
replaced u5110
replaced c7137
PPBUS_G3H - 8.57v
