820-3462 no backlight
Its a previous repair attempt, initially it wasn't turning on, fixed it and now there is no backlight, i checked backlight enable and that was low, so i tracked it and found that smc_lid is around 1.9v, removed r5050 and its a partial short, diode mode measurement is 0.081 and i have already reflowed smc and removed q5701 and nothing has changed so far, any other ideas apart from reballing or changing smc?
Remove C5050 and check if R5071 is OK.
If all correct, remove SMC and check again.
Probably short will go then, meaning bad SMC...
