820-3476 No turn on
MacLab
Hi all, this board came with corrosion on u7200,i clean the area and i change the chip but still the same
PM_SLP_S4_L missing but pulsing
PM_SLP_S5_L missing but pulsing
PP3V3_S4=0.4v (With 2 multimeters)
PP3V3_S3=0.4v (With 2 multimeters)
PCH_INTVRMEN_= 1.8V
PCH_DSWVRMEN_L = 2.1V
PPBUS_G3H =12.56 V
PP3V42_G3H =3.42V
PPVRTC_G3H = 3.3v
PP5V_S5 =5V
PP3V3_S5 =3.3V
PP3V3_SUS=3.3V
RTC_RESET_L = 3.3v
PCH_SRTCRST_L =3.3v
PM_DSW_PWRGD = 3.4v
PM_BATLOW_L = 3v
PM_RSMRST_L =3.3v
PM_PWRBTN_L = 3.4v
PM_PWRBTN_L trigger at the same time of SMC_ONOFF_L
Corrosion sign on CPU power supply is not good at all.
Check diode mode readings on all big coils; compare with good board.
Just in case, heat PCH/CPU with quality flux.
There may be accumulated crap underneath.
MacLab
The diode mode read is the same with a good board. I heat the PCH/CPU with AMTECH NC-599 and still have the same issue.
MacLab
In Smc bypass don’t turn in
L7320 pulsing
L7310 pulsing
L7630 pulsing
L7430 pulsing
Diode mode read in other rails looks fine
PP5V_S0= 0.4
PP3V3_S0 = 0.35
PP1V5_S0 = 0.35
PP1V35_S3_CPUDDR = 0.135
PPVTTDDR_S3 = 0.5
PP1V05_SUS =0.3
PP1V05_S0 = 0.138
MacLab
Sorry for my bad english and thanks for your patience!
With pins 5 and 6 joint the motherboard won't turn on
MacLab
Pin 3 off u1950 is pulsing with pins 5 and 6 joint but PLT_RESET_L not pulsing and in SMC bypass mode the board dont turn on
