Got an 820-3478 board in off an iMac 27" 2013 today but neither of the thunderbolt ports will work. If I connect a monitor to either of them monitor is showing connected no signal but there are no mirroring options coming up.
Is this likely to be burned U3210 and U3310?
Think you are correct as with further visual inspection U2800 looks discoloured like it has a burn mark on it. It's got like a brown spot on it.
Is there a source for replacement U2800 or it's a case of pulling one of a donor board only?
