820-3787 no image external/Internal
BCN_Techs
SMC_LID 3.4V.
I tried to connect external by HDMI and Thunderbolt nothing changes.
Usually this models get GPU hot when you turn it on. In my case it's completly cold. Only CPU is heating.
Why do you expect hot GPU, if doesn't get voltage?
You probably have a problem with U9600 now; reball it.
If no result, change it.
Maybe need to change U9300 too.
BCN_Techs
ok. changed ( reballed left same result. Changed both u9600 and U9300 for second time, but same result
Any other suggestion?
BCN_Techs
GMUX_SLP_S3_BUF_L is present 3.4V
And SYM 3 OF 3 Area cant see anything bad.
IF GPU is bad why its not powering even if bad.
I can only suspect bad GPU.
It has more blocks, apart of CORE.
Some of its blocks should talk with CPU, before GPU VCORE is enabled, I suppose.
Could even be a CPU issue, on the communication side with GPU...
