820 3787 not charging
EJS
820 3787 not charging battery, OSX recognizes the battery and charger. OEM 85w Apple charger, green/orange light on magsafe. 12.6 on PPBUS with board only, 12.9 with batt connected. 3.42 is present. Wrench symbol on battery icon, system says not charging. Battery has been replaced, no change.
"Battery has been replaced, no change."
Tested with known good battery, or just tried new chinese one?
Check system report in about this mac menu.
You should get more information about battery there.
EJS
New Chinese copy, but 3 different ones were tied, and behavior is exactly like the OEM that was pulled for this issue. System report battery info all seems to be present. Is there something specific you would like to know from there?
Cycles, charge capacity...
If all this info appears, then communication between SMC and battery is OK.
Check Q7155 voltages.
Also post voltage for U7100, pins 9, 15, 26.
Run ASD EFI version.
EJS
2info, system report does list, capacity, cycle count, ect.
Q7155
Pin 1 12.6v
Pin 2 12.61v
Pin 3 12.6v
Pin 4 jumps back and forth from 11.91-12.59v
Pin 5 power cycles between 11.58-5.6v
U7100
Pin 9 .412v
Pin 15 .058v
Pin 26 .022v
The ASD pack I have only goes up to early 2013 Pro, this is a late 2013 board
John B PPBUS is 12.6, board only
You should get proper ASD for test.
EFI version is good enough.
Try the batteries in other system, or get a known good one, even old, just for test.
EJS
I thought after after early 2013 they switched to ASD 2 which runs through the Apple servers? Do you know where I can get a copys for later machines?
ASD works untill 2014.
Your machine requires 3S162 version.
Use Google, it will probably find some torrent...
EJS
Those errors popped up because some of the cables were not connected. I put the entire machine back together, ran it again and everything passed. I also tried with a working OEM battery, still not charging.
EJS
Okay, just ran a 2nd time, and now its telling me temp sensor Th2H left fin stackprox is failing
That will not block battery charge.
But IPBR and ID0R will do.
Check again if these erros went off really.
EJS
Sure enough, it failed for IPBR and ID0R on this go around, and the other error disappeared.
