820-4668 No POWER - PP5V_S0 missing
mushr00m
iMac 820-4668 No Power
Only FIRST LED showing up
PP12V_G3H = 12.05V
Replaced the SMC same behavior
Power Rails as below
PP12V_G3H = 12V
PP12V_S5 = 12.05v
pp5v_s5 = 5.1v
PP3V3_S5 = 3.29V
pp5v_s4 = 5.1v
pp3v3_s4 = 3.29v
pp12v_s0 = 12.05v
PP1V2_S3 = 1.18V
pp3v3_s0 = 0v
pp5v_s0 =0v
Replaced U8400 / U8440 / U8420 Still same behavior
When trying to turn on through the PSU injecting 12V on it. It goes to 0.180a and back to 0.049 and keep stuck at it
mushr00m
u8500
1 3.28
2 3.29
3 3.28
4 3.29
5 3.28
6 3.28
7 0
8 3.26
9 3.29
10 3.28
11 0.398
12 3.26
13 3.27
14 3.29
u8600
1 3.26
2 0
3 0
4 3.29
5 0
6 0
7 0
8 0
9 0
10 0
11 3.29
12 3.40
13 3.28
14 3.29
My error, 1V05_S0 requires 5V_S0 presence.
As per datasheet, U8500/600 don't have open-drain output, so pin 11 of U8500 MUST be high, when both inputs 12 & 13 are high at same time.
Post again their voltages.
mushr00m
U8500
11 0.412
12 3.28
13 3.27
U8600
11 3.29
12 3.40
13 3.29
You stil have a problem with U8500.
Does it get 3V at pin 14?
Interchange U8500/600 and post voltages again.
Please, stop to quote an entire post, visible few centimeters above.
mushr00m
Replaced again and still 3.291 pin14 U8600 and 3.289 pin14 U8500.
Any other pin specific voltage are you looking
I am actually injecting 12V (2amps) directly into the PP12V_G3H to measure these rails since I am not able to do this with the boar assembled.
Is OK to inject 12V there.
But set the amp limit to max first.
I can't believe how many people still think that can adjust injecting current...
mushr00m
Still same result. The max on my PSU is 3A. I had an weird behavior I assemble back in the case and it tried three times to go to the fourth light
It light up the second one and the third one and the back to the only first one. It happened twice.
Could it be the reball of my SMC?
It's the only one thing I am in doubt with
mushr00m
I just assemble it back and now I am back to first sympton. It turn on and works sometimes and another times it doesn[t work and only one light. So PSU is not a problem thats what I assume since it turn on and stay stable for sometime.
My SMC is good soldered and working
PP5V_S0 appeared back when working.
After some minutes its OFF again and it trys to light up second light and it cannot it only blinks once. Really weird behavior actually I dont expect it to turn on out of nowhere. Btw it trys to turn on blinks second light and stay only on the first one.
But important to mention again I would disregard PSU, 5V_S0 line I guess its something which is causing the second light to blink and not stay stable.
Guess something PP3V3_S4 related
