A1398 820-3332-A not charging
hgoncalves
D6950 was (and still is) already out.
Diode mode:
SCL= 0.562V
SDA= 0.558V
Voltage:
SCL=3.4V
SDA=3.4V
As I have already replaced SMC, I want to check ISL6259 first, but can't find it in my schematics. Are you sure that is the one?
hgoncalves
The magsafe doesn't have light with the magsafe 1 (Original or PSU). However, with the original magsafe 2, it has a green light.
There is a problem.
Battery cannot be charged, if no correct Magsafe light.
Post again U6900/01 voltages in this case (no light).
Check R6950 and communication with battery connector.
Inspect the connector; measure on top of connector pins, instead of board pins.
hgoncalves
hi,
I have continuity between R6950 and the battery connector. The connector seams ok, on top and on back. However, i don't get any voltage on R6950 (don't know it it is supposed to have some voltage there without the battery connected).
hgoncalves
Without light:
U6900:
1 = 3.4 V
4 = 3 V
5 = 3 V
U6901:
1 = 3.2 V
2 = 3.2 V
4 = 3.4 V
5 = 3.4 V ( it rebooted when measured on first time)
The DC voltages are correct, missing communication I supposed.
You can confirm with o-scope.
Be sure to have good continuity between U6900 and central pin on the Magsafe connector.
R6950 just ties SYS_DETECT_L to ground, in order to enable to battery.
An o-scope can also confirm activity on SCL/SDA lines of battery bus.
hgoncalves
I have activity on SCL/SDA (attached img) but not sure if the correct activity (measured on SCL/SDA J6950 pins)
I have continuity between central pin of magsafe and the pin 5 of the U6900
hgoncalves
Yes, i have activity on 4 and 5 of U6900. The wave not as sharp as before (much more messi/faster) but i do have activity)
