pin 1: 18.16 Volt
pin 2: 18.21 Volt
pin 9: 4 Volt
pin 12: 3.4 Volt
pin 13: 3.3 Volt
pin 14: 3.2 Volt
pin 15: 0.074 Volt
pin 17: 2.5 Volt
pin 19: 5 Volt
pin 20: 4.6 Volt
pin 27: 19.98 Volt
I removed f7140/41. I disassembled the q7130/35. I changed the u7000 4 times. But again the u7000 is getting hot. It draws 0.08 amps. Currently there is no f7140/41 q7130/35 on the motherboard but it keeps getting hot
Removing good components will not help you.
Put all back; just be sure to be good.
Check any trace and solder.
Then post again U7100 voltages, above mentioned.
Change all capacitors surrounding U7100, if not sure about them.
Also change U7100, if still overheats.
