A1398 820-3662-a not power
tipoti
There were holes on the u7100. I change it. Q7135 was short I changed it. It draws 0.08 amps right now. U7100 warming up
diode mode SDA: 0.528 / SCL : 0.532
CHGR_ACIN : 4.7 volt
PDCIN_G3H_CHGR : 20 volt
PPBUS_G3H : 0,9 volt
tipoti
PPBUS_G3H diode mode : 0.463
R7151/52 no problem
R7121/22 no problem
pin 1: 18.16 Volt
pin 2: 18.21 Volt
pin 9: 4 Volt
pin 12: 3.4 Volt
pin 13: 3.3 Volt
pin 14: 3.2 Volt
pin 15: 0.074 Volt
pin 17: 2.5 Volt
pin 19: 5 Volt
pin 20: 4.6 Volt
pin 27: 19.98 Volt
tipoti
Pin 9 : 4 volt sure
I uninstalled the Q7180 but still the U7100 gets hot. Then I put a new one, nothing changed.
17/18 : 3.7 ohm
27/28 : 21.5 ohm
pin 27: 19.98 Volt"
PPBUS_G3H L7130 : 2.3 volt
tipoti
I removed f7140/41. I disassembled the q7130/35. I changed the u7000 4 times. But again the u7000 is getting hot. It draws 0.08 amps. Currently there is no f7140/41 q7130/35 on the motherboard but it keeps getting hot
tipoti
I removed all the ones with x to the top. But u7110 keeps getting hot
Removing good components will not help you.
Put all back; just be sure to be good.
Check any trace and solder.
Then post again U7100 voltages, above mentioned.
Change all capacitors surrounding U7100, if not sure about them.
Also change U7100, if still overheats.
Just keep out F7140/1.
