A1398 late 2013 random shutdown with black screen
NOOO.
Buy FDMF6708 from reliable store, like Mouser, or Farnell.
You can also use FDMF3030 instead.
FDMF6808 is Apple proprietary chip, never sold for anyone else!
SAD, It has 9 months to 1 year lead time in mouser and farnel, I may find some old board to remove this component. How are these buck converters are going bad? Is it only in the 2013 board? Will it be ok if I remove the component from an old 2012 board?
I am looking for a solution, Should I conclude that it can not be repaired until I buy it from Farnel or Mouser (With 1year delivery time ?)
Did you search for FDMF3030?
Using FDMF6808N chips recovered from scrap board cannot assure to get the problem fixed.
piernov
Moderator
FDMF6708N are in stock on Mouser here.
Also if you read pinned post you'll see that laptop_mb_seller/L2 Computers are old known scammers, never buy from them. And good luck finding genuine new ICs on Aliexpress these days, there's almost none. No one has new FMDF6808N anyway, they are all pulled from dead boards.
Yes, I have soldered them, Is there a way I can make sure I have soldered all three of them properly?
Because I can see 1.33V at the output, One out of three-chip is heating up too much...
I have used a hot air gun with a 500 deg temperature to remove the IC, the Same for soldering also... can I try to add more solder lead using a soldering iron.
Yes, I have removed the CPU heatsink before doing the rework.
