A1466 820-00165 0.11A and not turning on after a dead fly over P1V05S0_FB
it-solve
No core voltage on CPU core
U1950
PP3V3_S0 - 3.31V
ALL_SYS_PWRDGD - 0.1V
CPUVR_PGOOD_R - 3.32V
SYS_PWROK_R - 0V
PM_PCH_PWR_PWROK - 0.1V
PM_S0_PGOOD - 0V
PP3V42_G3H - 3.43V
Do you still have 1V at L7630?
If yes, check L7430, L7820 and all voltages from page 58 too.
Remove Q8150 and check ALL_SYS_PWRGD again.
it-solve
L7630 - 1V, only coils I dont have voltage are CPU core
L7430 - 1.21
L7820 - 1.8V
PP1V5_S0 - 1.5V
PP3V3_S0 - 3.32V
PP3V3_S4 - 3.31V
PP3V3_S3 - 3.32V
PP3V3_S5 - 3.32V
PP3V3_SUS - 3.33V
PP5V_S0 - 5.09V
PP1V05_S0 - 1.06V
Removed U8150 and turns on ALL_SYS_PWRGD - 3.33V
it-solve
got it running without u8150, remembered you mentioning that we don't need it. shall i leave it off?
Can load up now and everything seems to work ok on external drive, apart from not detecting the SSD. Tried with 2 spares and none are detected. I can load via USB and seems stable
Did PRAM reset
PP3V3_S0SW_SSD_FET_R - 3.3V
SSD_PWR_EN - 3.2V
Q8150 is a redundant protection.
If the 3 power rails supervised by it are good, no need to resolder it.
Post U3740 voltages.
Check all pads of SSD connector and its traces.
it-solve
U3740
P3V3SSD_VMON - 0.99V
SSD_RESET_L - 3.28V
SSD_RESET_CONN_L - 3.42V
SSD_PWR_EN - 3,23V
Cleaned the pads, and tried with spare SSD
it-solve
Not Detected at all, tried another bunch of SSD and getting ? mark. Not even one deteced under Disk Utility or System Report
Cleaned the traces and rechecked for any damaged/corroded components around. None
