hgoncalves
I have an A1466 820-00165-A that seems to have a bizarre behaviour. The client says that the mac sometimes, doesn't power on. Here it was working, without any problems, for 3 days (several power on and power off), and on the fourth day it didn't power on.
After I disassemble the board to diagnose, the board start working again without any problem, and all the measures seem to be ok (because it is powered on i assume).
I mounted the equipment on the unibody, and the problem happens again after 5 days without any problems, until it stooped, and on the bench it works again.
Do you have any idea? What should i check from here?
Thanks.
Thanks.
