A1466 820-00165-A no power
Thats what I meant (5A max amperage set in PSU, witch is the max in my PSU).
I started with 1V and increased until 4V, because i couldn+t find anything hot. With 1V, it consumes 1.5A in PSU.
I'll try without the heatsink.
Hi, I am sorry, but I'm really not understanding this.
Now, without any intervention from me (just take out the heatsink), the first time i plugged the laptop this morning to the PSU, the 3V42_G3H is no longer shorted, and has 3.4V...
It has green light, but no fan sin and no power (20 mA on PSU).
I have all these good voltages:
PPBUS_G3H
PPBUS_S5_HS_COMPUTING_ISNS
PPBUS_S5_HS_OTHER_ISNS
PPDCIN_G3H_ISOL
PPDCIN_G3H
PP3V42_G3H
PPVRTC_G3H
PP5V_S5
But on PP5V_S4RS3 I get 0V (even on C7606)
Do you have any idea or should i give up on it?
Looks like partially shorted cap, I saw this several times; the shorted part got burnt when injected voltage.
Now check power on sequence.
I think i have all S5, but it starts missing in the S4s.
GOOD:
PPBUS_G3H
PPDCIN_G3H_ISOL
PPDCIN_G3H
PP3V42_G3H
PPVRTC_G3H
PP5V_S5
PP3V3_S5
FAIL:
PP3V3_S4 = 0V
PP5V_S4RS3 = 0V
Shel i check anything more?
HI,
Just saw that the R1617 is missing and the pads are gone. R1632 and R1410 also W/O one pad and lose...
There are several resistances around that area that seam to have a bit of corrosion.
PM_DSW_PWRGD = 3.4V
PCH_DSWVRMEN = 3.2V
PCH_INTRUDER_L = 3.0V
PCH_INTVRMEN = 3.2V
PCH_SRTCRST_L = 3.3V
RTC_RESET_L = 3.3V
Can't it be the missing R1617 (previous reply)?
I supposed you already rebuilt traces and resoldered ALL missing components.
PCH will not start power on sequence if R1410 is missing.
I try to figure out where PP3V3_SUS is created but couldn't find it. Can you please tel me in what IC that tension is created, so i can try to follow the track?
