A1466 820-3437-B no power
hgoncalves
Hi, I have an A1466 820-3437-B that the client report that stoped working without no reason
I have green light, fan spin, CPU gets hot, and get voltages on big coils.
I have:
PP5V_S0 = 5V
PP3V3_S0 = 3.3V
PP3V3_SUS = 3.3V
PP1V05_SUS =1.06V
PP1V5_S0 = 1.5V
PPVCC_S0_CPU = 1.74V
Can it be BIOS?
Can you help?
Could be BIOS, even bad CPU.
Check first if PLT_RESET_L is high.
Also check for USB activity.
hgoncalves
Can't find no Clean ME on the forum. Do you have itt please? Do i need to change the serial, even on clean me?
hgoncalves
II should have done something wrong in the first flash.
After re-flashed bios I get fan spin, but no USB activity.
PLT_RESET_L = 3.3V, CPU gets hot and it consume arround 0.550 V on PSU
hgoncalves
R6128 = 24.80 ohms
R6127 = 43.00 ohms
R6126 = 42.45 ohms
R6125 = 42.67 ohms
R6110 = 14,88 ohms
R6120 = 42.28 ohms
R6111 = 15,05 ohms
R6121 = 42.55 ohms
R6112 = 14,65 ohms
R6122 = 42.20 ohms
R6113 = 14.84 ohms
R6123 = 24.87 ohms
R6114 = 24,85 ohms
R6115 = 14.94 ohms
R6116 = 14,77 ohms
R6117 = 14.72 ohms
R1540 = 33.18 ohm
R1541 = 32.96 ohm
R1542 = 33.97 ohm
R1543 = 33.10 ohm
R1544 = 32.94 ohm
All traces seems to be normal
