a1502 820-4924-A Liquid Damage... no image, but boots when Magsafe plugged in
papalati
Nope, I was an idiot and did not connect both cables to the RIO board. Now USB and HDMI work as well.
Still no internal display. Put in the good board and I can see the cracked lcd display. Put in the bad board and no display at all.
What next? Backlight display?
Image should appear first.
To avoid any artifact, or improper image on the display, the backlight appears with a small delay.
Do the mentioned tests about internal LCD output...
"When you start the board with internal LCD connected, check for voltage at R8320 pads.
You should also get voltage there in the first few seconds at least, even without LCD.
Keep the multimeter probe connected there when turn on the board; especially when hear the chime"
If voltage is stable, then must have voltage at LCD_HPD_CONN and DP_INT_HPD; is better to confirm.
You should also have image on internal LCD, check with flashlight.
Now check BKLT_EN_R and volatge at both pins of D7710; LCD connected, of course.
papalati
Voltage is stable on pad 1. Voltage starts stable on pad 2 then fluctuates for a 2-3 seconds then becomes stable again and stays at 5v. Happens exact same way every boot.
LCD is too cracked to see any image. Even when good board is in the only thing I can see is just 2-3 cracks of light can't even see the little folder with question mark.
On D7710 - Pin 2 is .005 and Pin 1 is .023 while internal lcd is connected. That is no good I'm assuming.
"On D7710 - Pin 2 is .005 and Pin 1 is .023"
Diode mode to ground?
I hope you've disconnected power first.
BTW, I was asking for voltage at D7710...
papalati
That was voltage at d7710. Power was connected. :(
I thought you wanted it to be powered on since we just checked voltage on r8320 with power on. Sorry.
Pin2 was .005 volts and pin1 was .023 volts. NOT diode mode. That's why I was assuming it was bad since not that many volts were showing on ppvin and out.
Correct, I wanted voltage, but your values look more than diode mode; 3 decimals used for that usually.
For voltage, you could write just 0V, no differenece.
BKLT_EN_R still not posted.
Please, do note quote an entire post visible few centimeters above...
papalati
BKLT_EN_R at R7742 is 100.7
BKLT_EN_R at C7742 is 100.7
BKLT_EN_R at Pin 17 on u7700 is 100.7
I no longer have the good board, so I was not able to compare, should there be a component at C7742? Cause it is just an empty pad? I attached best pic I could get. I thought R was for resistor and C for capacitor, but there is no capacitor at C7742 I can see.
All the components marked as "NO STUFF", are not present on the board.
Need the voltage at BKLT_EN_R; one point is sufficient...
So enable is present, lets check adjust somehow.
Post diode mode and voltage at BKLT_SCL/SDA lines.
Also post voltage for BKLT_SD.
papalati
Q7700
Pin 1 = 0v
Pin 2 = 0v
Pin 3 = 12.48v
Pin 4 = 12.58v
Pin 5 = 0v
Pin 6 = 0v
F7700
Pin 1 = 12.58v
Pin 2 = 12.58v
"BKLT_SD = 0v"
If this is correct, you should have 5V aprox on pin 3/Q7700.
Check R7701/02; measured onboard, ohm scale.
I'm not sure what that means.
I expected to measure each resistor value (between pins 1-2), not to ground.
Very important to know R7701 value!
Explain what you've measured.
If both resistors are good, then change Q7700...
