A1708 820-00840-A 5V 400ma
Need to do that to get acces to the pins.
In case, the same pins do not have another available test points on their traces.
I have replaced the charging port and now I get 20v 200ma however there is no post. I check the traces and they are good. I then checked all the old readings and there is no change.
Checking everything again this morning. Now not getting some LDO rails and not getting PP3V3 or PPBUS. Still at 20v 200mA.
U3100 Pin 2 PP1v8_UPC_XA_LDOD = 1.8v 0.452,, Pin 12 PP3v3_UPC_XA__LDO = 3.284v 0.477,, Pin 35 PP1v1_UPC_XA_LDO = 0v 0.461,, Pin 75 PP1v8_UPC_XA_LDO = 1.78v 0.483
U3200 Pin 2 PP1v8_UPC_XB_LDOD = 1.79v 0.448,, Pin 12 PP3v3_UPC_XB__LDO = 3.32v 0.478,, Pin 35 PP1v1_UPC_XB_LDO = 0v 0.457,, Pin 75 PP1v8_UPC_XB_LDO = 1.8v 0.48
PP3V3_G3H = 0v 0.338
PPBUS_G3H = 0v 0.394
The problem is not in USB-C area, if you get 20V on both USB-C ports.
Do you get R7020 voltage?
Post diode mode to ground at F7000 and L6995.
For the future, do not waste time searching for iGPU voltage; nor even on working board!
"I thought I was that was the "big coils""
And you've only seen L7410/20/30 ont the board?
I said big, not biggest.
There are some other smaller coils, which enter in the same "big" category.
You've just stopped on the irrelevant ones.
Post D6905 voltages...
So you have 13V at PPBUS_G3H.
That implies correct 3V3_G3H also.
"PP3V3_G3H = 0v 0.338
PPBUS_G3H = 0v 0.394"
Can you tell us which is the actual situation for sure?
I was getting different readings due to my power tester. Sometimes when I unplug from the board and reinsert the tester will say 20v but amperage was 50mA (which I did not see). Power cycling the tester brings it back to 200mA.
Apologies.
Did you check at same time when trigger SMC_ONOFF_L?
Do the same for PM_PWRBTN_L; should catch a drop pulse there.
