A1708 820-00840-A 5V 400ma
USB-C pins check diode mode to ground
CD3215 side
0
OL
OL
0.132
OL
OL
OL
OL
0.132
0.331
0.329
0
0
OL
OL
0.132
OL
OL
OL
OL
0.131
0.333
0.333
0
Opposite CD3215
0
OL
OL
0.131
0.600
OL
OL
OL
0.130
0.333
0.332
0
0
OL
OL
0.130
0.596
OL
OL
OL
0.128
0.331
0.330
0
Yes. The two damaged pins (which are on the same side of the board (CD3215 side) but different socket) are the only ones that give a different result. Those pins give OL on the damaged board and 0.600 on the working.
Try to identify the corresponding traces.
The working board can help you.
You may need to change the USB-C board.
Should practice in scrap board first...
Boardview and schematic don't show USB-C port terminals.
You must find corresponding points in the MLB, checking continuity from J3300 to USB-C terminals.
You will need good board to find the traces; the bad one doesn't have continuity.
If broken traces are not in MLB (or bad solders at J3300), then need to change the USB port...
You have broken trace for sure.
You must get the same readings on diode mode at USB-C terminals like good board.
