well i put the system back together using the "fixed" board and it ran for while until unplugged it and then it would not come back on. It turns out that pbtn_out# failed again so i flashed the EC and now this board is doing the exact same thing. This is a revision 2 board but i used the firmware files for the original la-g881p (A00). Now I'm convinced that it's all just firmware related
One of the boards has an intel ME issue. It takes about ten seconds to post on a cold boot. I tried to clean the ME section of the dump and the hard drive doesn't detect with a cleared ME. this board has intel boot guard and i toggled with the setting but still no luck
when i add the clean ME region then the hdd won't detect in the bios. It detects with the old dump. Is there a way to repair the ME without using flash image tool?
i have another one of these boards. the cpu vcore is missing. Imvp_vr_on is 3.3v. the fans spin then stop. pm_slp_s4 remains at 3.3v after the fans stop.
