i've found this
Once the T2 is powered from the above rails, it will read its ROM (U4770.) The T2 will then begin to start its boot up process, in which we will initialize the below rails.
PP3v_G3H: Normal voltage is ~3.0v. Produced from U7800, powers some PCH functions.
PP5v_G3S: Normal voltage is ~5v. Produced from U7650/Q7660.
PP3v3_G3S: Normal voltage is ~3.3v. Produced from U8210.
PP1v8_G3S: Normal voltage is ~1.8v. Produced from U8220.
The SSD power is then enabled to allow the T2 to boot BridgeOs.
PP1v8_VCCQIO_SSD0: Normal voltage is ~1.8v. Produced from U7800.
PP0v9_SSD: Normal voltage is ~0.9v. Produced from U7800.
PPVCC_NAND_SSD0: Normal voltage is ~2.5-2.7v. Produced from U9060.
Once the SSD is powered, and BridgeOs boots,
SO IS IT POSSIBLE THAT T2 doesn't enable those power rails for some reason?
