[help]imac 21,5 a1311 820-2641! is it a kind of magic?
ok, problem is that i have no imac motherboard anymore...only macbook motherboards...do you know if there is something compatible ? i have a lot o a1466 and a1502 board and other boards
u3404 is the same in those boards, so i've changed it...now i should chsnge q3403, but i don't know if it is compatible. please help
i'm going crazy because i'm not 100% sure like before that problem is related to wifi card. i've done dozens of tries (on/off) with and without the card:
90% of times it doesn't boot with card inserted. 10% it boot with card inserted
90% of times it boot without card, but 10% of time it doesn't boot even without card..
aslways with same behaviour (one led that disappear after power on). if the led disappear, the only way to boot the computer, is to remove and reinsert the power chord
what can i measure when i have the problem?
is there any way to boot the motherboard with my bench power supply?<
ps same problem even with 1 ddr only
changed u7700, now system boot but now wifi card :( i'm going crazyyyyyyyy!!! what should i check about the wifi card?
