Mac Air 820-00165 green light , no backlight , dont charge
Petro
i have a mac air with green light , it's taking to much current when battery and charger are plugged in ?
I don't exactly understand what you mean...
Please post accurate information.
Do you get image and missing backlight?
Petro
Mac works normaly on battery but when i plug megsafe charger the board is going hot and charges to much amps .
also pin 17/18 on u7000 resistance is 150 omhs ??
fixed backlight bad chip .
Petro
I changed R7151 with high omhs , now normal value 2.45 ohms . but it's not turning On . both ppbus , pp3v42 available ! what to check now ?
Petro
PPbus_g3h = 8.59v
PM_BATLOW_L = 3.42v
it turns now ON ! when i unplug the LIO Connector it turns on but when i plug the battery its charge to much amps . but it stays on with battery when unplug charger ?
Very unclear...
Do you really ask if stays on in such case?
Cannot test???
Looks like you have a problem with LIO board, or flex...
Petro
I tries 3 lio boards and flex cable still the same board looks clean. The problem is only when i plug the battery in and starts charging to much amps .
Petro
No i dont have another one , but why it turns on only on battery without charger but dont charge ?
"The problem is only when i plug the battery in and starts charging to much amps
it turns on only on battery without charger but dont charge"
You really mix the things and make hard to understand you.
Don't charge, but take too much ampers charging; very unclear/confuse, as I said...
Please specify:
- does it turn on on charger only?
- does it turn on battery only?
- does it turn on with both charger and battery connected?
And use original Magsafe 2 charger!!!
Petro
ok Sir,
- does it turn on on charger only? --- Yes only by SMC bypass !!
- does it turn on battery only? ---- Yes , just by pressing power button or shorting smc_onoff !
- does it turn on with both charger and battery connected? Yes , but the board is getting Hot on both magsafe2 and powerDC !
You didn't mention about SMC bypass before; very imporrtant info!
Check SMC_PBUS/DCIN_VSENSE on charger only.
Also post SMC_BMON/DCIN_ISENSE.
Take a look at SMC_BMON_DISCRETE_ISENSE too.
Petro
Sir,
SMC_PBUS_VSENSE = 000.0V
SMC_DCIN_VSENSE = 3.092v
SMC_BMON_ISENSE = 059.0mv
SMC_DCIN_ISENSE = 038.0mv
SMC_BMON_DISCRETE_ISENSE = 164.3mv
