Macbook A1706 820-00239. doesn't see ssd.
ipetro
The MacBook works completely except for the SSD. I replaced the SSD and S3X from the working board but nothing has changed, he still doesn’t see the ssd.
ipetro
lifebot deleted used jumpers
PCH Side===SSD Side
PPBUS_G3H=13.10v=PPVIN_2V7NAND_LB
PP5V_S4=5.13v=PP5V_S4_P2V7NAND_LB
SSD_BOOT_L=1.780v=SSD_BOOT_LB_L
SSD_PWR_EN_L=0.030v=SSD_PWR_EN_LB_L
STORAGE_EN=3.321v=STORAGE_LB_EN
SSD_RESET_L=3.327v=SSD_RESET_LB_L
SSD_CLKREQ_L=0.092v=SSD_PCIE_CLKREQ_LB_L
PCIE_SSD_D2R_P=0v=PCIE_SSD_D2R_LB_P
PCIE_SSD_D2R_N=0v=PCIE_SSD_D2R_LB_N
PCIE_SSD_R2D_C_P=0.690v=PCIE_SSD_R2D_LB_C_P
PCIE_SSD_R2D_C_N=0.695v=PCIE_SSD_R2D_LB_C_N
PCIE_CLK100M_SSD_P=0.432=PCIE_CLK100M_SSD_LB_P
PCIE_CLK100M_SSD_N=0.427v=PCIE_CLK100M_SSD_LB_N
SSD_SR_EN_L=3.195v=LPSR_EN_LB_L
PP3V3_S5=3.351v=PP3V3_S5_SSD_LB
Any fault history available?
Compare signals voltage with good board.
As last option, you can consider to replace with M2 NVME SSD.
ipetro
The MacBook was erased for sale, but when I tried to install a clean system, the disk was not detected!
I bought an identical board on which the system is installed, but it only works for an external display and I removed the SSD from it without receiving the SSD, I transferred the S3X and still no SSD. Is it possible that the problem is in the Thunderbolt? I only get two 3.3V voltages for a moment and then disappear, but they should stay there, or am I wrong?
TBT_T_CLKREQ_L=3.3v and immediately zero
SSD_PCIE_CLKREQ_LB_L=3.3V and immediately zero
