Macbook A1706 Stuck at 5V. No PPBUS
Put correct 2.2 ohm for R6907.
However, it is used only in battery mode.
Charger powers up through R6902.
You should check if D6902 is OK; or just replace it.
Your problem may be on the 3V42_G3H line, but first assure to have good R/D6902.
i just replaced D6902 and i now getting ppbus and 20V on the amp meter. Let me put it back to the chasis and see if it boots up
It was working well but one fan wasnt spinning. So i removed the board and saw that the fan wasnt connected ( the one that connects to the keyboard.
after connecting that fan started spinning very fast so i disconnected it and the machine went dead again. Same short as before. Working on it again. Is the fan bad ?
Had to replace the Capacitor again.
Diode D6902 Pin 1 has no voltage again. Replacing that too.
It will not boot with battery connected and amp meter reboots every2-3 seconds on all 4 ports.
Without battery it boots up fine
Check resistance (ohm scale) over C7020/23.
Did you try known good battery?
What is exact PPBUS_G3H voltage?
I dont kow how it happened but it got knocked off again. Now the point is missing from the board so i had to run a jumper wire from the test point on other side of the board to pin 2 of R6051. I get diode mode reading of .750. But still it is not working on battery.
C7020/3 is 2.9 Ohms.
Tried a known good battery.
PPBUS_G3H
Without Battery Connected 13.09V
With Battery Connected 12.09V
Q7560 Voltages
With Battery Connected.
All at 12.07V Only TBA_BGATE at 4.2V
Without Battery
All at 13.09V
SCL/SDA Lines at the Battery Connector is .430 Diode Mode to Ground.
If i connect the charge first and the connect the battery after machine is booted. Restart it.
It detects the battery. Charges it too.
If i shut it down with charger connected and switch it on. It boots up normally as well.
But it switches off i remove the charger.
My hall sensors are working fine too. ( Was going through another post on this forum)
Do you mean Q7065, instead of Q7560?
Then it is open to charge the battery; as per your readings.
R6051 is not related with the battery.
Be sure R6950 is good.
[UPDATE]
With Internal LCD Disconnected and external video connected the machine draws a steady 20V and i can see the apple logo on the monitor. But it gets stuck there.
Can it be a Hall Sensor Issue ?
Then ? It worked randomly for sometime with the battery. But then again after sometime back to this. I dont have a known good battery to eliminate if its a battery issue. Any other checks?
Hi, i got a working battery to test. Its not working.
Moreover the machine went dead again stuck at 5V
again i see PPVIN_G3H_P3V3G3H is shorted .
I ll remove all components and check again. If its D6902 then it will be the third time i ll change it.
Why is it getting shorted ?
