Macbook A1708 820-00840-01
zcinciev
Hi guys.
I have this board which has 2 type c ports of which only one the second port works ad charges normal. This happened after using a dongle and i noticed some sticky thing on the board which i cleaning as much as possible. Any advice?
Thanks
The other port stuck on 5V input?
Probably bad CD3215 chip.
Compare diode mode readings on power rails of both chips.
zcinciev
On F3000 i get 20v and on F3010 i only have 5v...
Also C6424 and C6404 are shorted on PPBUS_G3H_SPKRL...
Lot of caps connected to PPBUS_G3H.
Did you remove these two and find them shorted out of board?
Post exact resistance to ground (ohm mode) at PPBUS_G3H and all big coils.
Also seems to have problem with U3200, or its area.
I asked about PPBUS_G3H; diode mode, not ohm scale.
If is really low value, or short; then use ohm scale.
zcinciev
48.8 ohms on L7430 ... and PPBUS_G3H_SPKRL also a lot of caps touching the ground :D
Also when plugged in on U3100 on F3000 i have 30V and on U3200 6.8v
"48.8 ohms on L7430"
I repeat
"I asked about PPBUS_G3H; diode mode"
"PPBUS_G3H_SPKRL also a lot of caps touching the ground"
You have a fix with PPBUS_G3H_SPKRL.
Did you remove R6499 to be so sure is only there???
This is the reason for pending measurment asked above.
"on U3100 on F3000 i have 30V and on U3200 6.8v"
Change the battery of your multimeter and check again voltages.
