I have this board which has 2 type c ports of which only one the second port works ad charges normal. This happened after using a dongle and i noticed some sticky thing on the board which i cleaning as much as possible. Any advice?
Lot of caps connected to PPBUS_G3H.
Did you remove these two and find them shorted out of board?
Post exact resistance to ground (ohm mode) at PPBUS_G3H and all big coils.
Also seems to have problem with U3200, or its area.
"48.8 ohms on L7430"
I repeat
"I asked about PPBUS_G3H; diode mode"
"PPBUS_G3H_SPKRL also a lot of caps touching the ground"
You have a fix with PPBUS_G3H_SPKRL.
Did you remove R6499 to be so sure is only there???
This is the reason for pending measurment asked above.
"on U3100 on F3000 i have 30V and on U3200 6.8v"
Change the battery of your multimeter and check again voltages.
