Macbook A2289 820-01897-06 M1 Dead
This Mabook Macbook A2289 820-01897-06 M1 came in dead after severe water damaged , when Connect my amp meter I can see that my 20v DC is ok and pulling 11Watts and 10.5 amps and stuck there , Fan spins but no boot , Can i please get some help ?
Thank you very much .
Isn't your board 820-01987?
Did you try DFU mode?
Was the board cleaned and corroded components replaced?
correct my mistake my board is 820-01987, I have not tried DFU mode yet , I spotted some corroded areas including the fan connector was gone and i rebuilt it , but all the other places were fine and no shorts found, but i realize that CPU gets hot .
TCRScircuit
Super Moderator
This isn't an M1 board. This is Intel. Also you aren't pulling 10 amps. Post voltage on L7210.
Can be CPU, or accumulated crap under it, or other BGA chip.
A simple corroded resistor can be also enough to block the board.
Did you try DFU at least?
No, I have not yet tried the DFU mode , Would you please provide me with the combination keys to get it into DFU mode ?
Thank you .
I will also review the resistors to see if any of them is corroded.
Thank you for the informations , i have tried to to get the device in DFU but was not succeded , i wanted to add a short preview video to show you the reaction on the AMP meter , i have added a clear picture . Thats where the device stuck on .
