Macbook A2289 820-01987
If machine works from battery and load macOS, you must center on USB-C area.
Just in case, check voltage and diode mode on SCL/SDA lines of battery bus; before and after Q6950.
You can try flashing TBT ROM now (U2890).
Right , I said the same thing too , since its booting properly, I will check voltage and diode mode on SCL/SDA lines of battery bus , then Q6950, For U2890 I don't have any dump files here to flash it , do you have another way of doing so?
Thanks for the infos, I am getting this one which is showing very advanced and easier to deal with , Let me know if its adviceable.
BY-U301 DATA ASSISTANT FOR MACBOOK READ WRITE BACKUP REPAIR
The device came with the instructions and its software even the Bin files for all the other macbooks are included , but i am not sure when i read U2890 it goes fine but as so on as i try to write the file on it its giving an error saying chip is not properly inserted or there s a problem with the chip, I went back to run a few check to see and I found those power rails :
TBT_X_SPI_CLK , = good diode mode reading but 0.00V
UPC_XB_SPI_CLK = good diode mode reading but 0.00V
PP3V3_G3H_RTC = 0.70 low diode mode reading 3.3V is that normal?
I am waiting for the seller to contact me , I dont know if causing the issue and can that chip be changed directed if i rewrite the data on it .
