sourcensolutionsonline@gm
The readings I have sent was without battery connected , as I pulled the board out of the top case.
R7020 is intact i zoomed it under the scope with very clear view no physical damage, but I can replace it by a new one if you suggest me to , which side of R7020 I should measure to get the 10V ? is PPDCIN_G3H or PPDCIN_G3H_ CHGR? also AUX_DET is on low voltage should i trace components on that line to see if anyone is slighly damaged which could cause the low voltage?
Please advice thank you very much , I got this laptop for a while and customer is now driving me crazy.
