Earlier when i tested 3V3_G3H_RTC was not present, but PPBUS_G3H was always 12.26V
I dared to replace U6903 Was just for a test since then 3V3_G3H_RTC is present as well as PPBUS_G3H , But I found out U3200 gets super hot when USB Amp Meter is connected on one side , on the other side the USB Amp meter only flashes but not showing the 5V and also PP3V3_TBT_X_SX is on low resistance on diode mode to ground 0.03 and when I injected 2V from the dc power supply to see what would get hot , it happens that U2800 Gets warm, would you have any suggestions? I was thinking of changing both U3100/200 And reball U2800 to see if that would make a difference.
Can U2800 be replaced or only reballed, U2800 PP3V3_TBT_X_SX is my problem, let me know if that chip is not an encrypted chip , so that i can either change it or reball .
Do you think a massage to a wood foot can help?
If U2800 is shorted to ground, can't reball it; must be replaced.
Pick it from another board, it should work; let us know.
Just a quick Question i have , I found U2800 From a A1989 Macbook but both chips marked Intel E1 but the numbers are a bit different
The one that i am working on the marking is : T803A900 which is shorted , and the one i am harvesting from the A1989 marking is U803G901 Let me know if that matters before i remove it and reball it .
U2800 was replaced but still no 20V on my USB amp meter all the 3V3 Lines are ok included PP3V3_TBT_X_SX that was shorted earlier, Please suggest what might've been my issue.
