Macbook A2337 820-02016
iFix
Hi guys.
I have this board with no power stuck at 5v 0.55amps and small fluctuations on the side of the amps. On the thermal camera, U5200 pulses. No short on U5200 and surrounding components, no liquid spill, and no voltages going to the PMU U8100. Would appreciate your help on this. Thanks
iFix
U5700:
pin 8 PPBUS_AON - 4v
pin 7 PP5V_AON_P3V8VRLDO - 0v
pin 5 P3V8AON_PVCC - 0v
ENABLE - 0v both sides of R5710
"PPBUS_AON is present and goes from 11.9 up to 12.2v"
4V isn't in that range, no?
"pin 8 PPBUS_AON - 4v"
iFix
U5700:
pin 8 PPBUS_AON - 11.8-12.2v going up and down
pin 7 PP5V_AON_P3V8VRLDO - 5v stable
pin 5 P3V8AON_PVCC - 5v stable
ENABLE - 5v both sides of R5710
I mean that U5700 should already deliver 3V8_AON.
It has correct power and enable.
Check all surrounding components.
You may need to change U5700.
iFix
Yes, I checked the standby sequence and checked all surrounding components all measure fine, searching for a spare U5700 from a board. I will update once I replace it
iFix
The client couldn't wait for a new chip to arrive they bought a new laptop. Thanks for the help :)
iFix
Hi. He came back, I replaced U5700 and U5200. The pulsing of U5200 now it's not there and I have power cycling 5v and 0.04-0.05 but it goes at time 0.100.
PP3V8_AON_VDDMAIN is 3.8v :unsure:
