Macbook A2681 LAS Issue
Instafixx
Device Reboots when LID is closed and opened.
When LID is closed device shuts down and when LID is open device turns on.
I also get a panic report when this happens.
Happens if i manually put it to sleep.
Initially this was an intermittent issue but its there.
I remove the LAS. Put the machine to sleep manually and the machine reboots.
With external display connected - the machine will sleep/wake normally for the first 3-4 times before giving the same issue.
I updated to Tahoe. But ho to recalibrate the sensor. the repair assistant only has triage options.
Close the LID - wait for 5s. Open - No Problem
Close the LID - wait for 4s. Open - No Problem
Went down to 1s. No Problem.
Problem arises when the LID is closed and opened almost instantly.
Check this out
Even with LAS disconnected- if i manually out device to sleep, it behaves the same way.
Wait for sometime and it will Wake Up normally.
Instantly press any key and it reboots.
