MacBook Air M2 A2681 820-02536 short on PP5V_CHGR
mgladin
Hello!
I am looking at a MacBook Air M2 A2681 820-02536 that came in not charging. When I plugged the MagSafe charger in, there was no light, and USB-C did not work either. I tried replacing the battery just in case, and that did not work. I pulled up the boardview file and started checking the connections at the battery connector and found a short on PP5V_CHGR. I initially checked in diode mode, and when that showed shorted, I switched to ohms and found that it measured at 0.3ohms, indicating a short. Boardview shows PP5V_CHGR goes all over the board, so I have no idea where to even begin trying to chase it down. No signs of water damage, did not want to inject voltage since the APU and NAND were highlighted.
mgladin
They read at 0.3ohms on the PP5V_CHGR side, but the other side does not present a short. PP1v8_AWAKE show 7Mohms on C5277 and PP3v8_AON shows 300kohms on C5360
What schematic used there?
C5360 is connected to PP5V_CHGR, not to 3V8_AON!
Also C5277 is connected to PP5V_CHGR_VDDP, not 1V8_AWAKE!
"They read at 0.3ohms on the PP5V_CHGR side"
No idea how to interpret this; one side of capacitors is connected to ground.
I hope you didn't waste the time checking from GND to GND.
BTW, use diode mode, with red probe connected to ground!
mgladin
I was looking at the same brd file that you just sent me. Am I missing something or just being dumb?
mgladin
After looking at the schematics (which admittedly I am not very good at reading or understanding), I think the boardview has PP5V_CHGR and GND mixed around or combined?
mgladin
Got the new software installed, it looks a lot better. Two points you asked about earlier are fine.
EDIT: C5360 PP5V_CHGR reads at 0.535 and C5277 PP5V_CHGR_VDDP reads at 0.426.
