MacBook Pro 2017 13" will not turn on after screen replaced?
RicardoV
Not sure if I can get some direction on this I replaced a screen on my laptop without disabling the autoboot now my laptop won’t power on. I have read in some forums some people having the same issue but they could power on without having the battery connected my laptop will not power on with battery connected or if battery is disconnected. I was going to attempt to find a short on the logic board so I purchased a usb-c volt and amp reader and it appears as if I’m getting normal power to the laptop 20v’s and amps vary. So I’m thinking I’m not seeing a short in the logic board could it be that I may have a defective power button? I’m not sure any thoughts on what I should try next?
Didn't disconect the battery, when swapped the screen?
Check for voltage on all coils.
Post the exact 820-xxxx code of your board.
RicardoV
Yes battery was disconnected when I installed the screen. I removed that pancake screw and unplugged the battery only thing I didn't do was disable autoboot which everyone says you have to do. I haven't removed the board yet but should be the #820-00239 051-00515 (A1706 EMC 3163).
RicardoV
Sorry I am a complete noob to troubleshooting these macbook computers. Because it involves more work on the mother board I don't have any experience besides what I watch on youtube.
RicardoV
No unit does not power on at all, the fans to not start up so nothing on keyboard is lighting up. I thought maybe the screen was the issue so I reinstalled the old screen and the computer still does not power on.
RicardoV
At this point its more of a figure out project. I'll take it apart and see what I can find what should the amperage be roughly? I bought the usb-c amp reader and get 20v's but amperage is kind of all over. I'll take it apart and see if anything stands out.
You will need to check voltages in several points, as all big coils first.
Need to identify the board (820-00840/875 matbe) and get schematic/boardview.
RicardoV
Ok model of board is 820-00923-A I'm looking around to see if I can find a schematic for this. Once removed from case I still get 20V and about .37 amps when plugged in.
All big coils.; some of them (iGPU) will not have voltage as normal.
We need your voltage readings to see how to continue.
RicardoV
Ok man I've had to watch a few videos before I attempted this but I hope it makes sense so I tested a whole bunch of coils with the majority coming out with 0 v. There is a coil L7030 that is the biggest on I could find on this board and I am getting a reading of 13v's on both pin 1 and 2. At one point after about 10 mins the amps dropped significantly to about .02-.04 and that same coil L7030 was only getting 3V's on both pins.
You should check if always get 13V at F7000, not L7030.
But we need voltages from other coils; like L7600/60.
RicardoV
Ok first man thanks for your patience I have tested F7000 I am getting 13V and I also tested L7600 I am getting 5v and L7660 is getting 3V.
I also followed through the chain followed PPVBAT_G3H_CHAGR_REG path and found C7050 and C7051 and 13v was present at both of these locations. Any other locations you'd like me to check out?
L7410/20/30 don't have voltage as normal, check all other coils.
Also see which voltage remains when the current drops to 0.02A.
RicardoV
Ok here's the info:
L7410 - goes up to 0.16v but then goes back to 0
L7420 - 0v
L7430- 0v
L7210 - 0.46v
L7220 - 0.48v
L7700 - 1v
L7900 - 1v
L8000 - 1v
L8050 - 1v
L9400 - 2.7v
L3500 - -0.03v to 0.03v
L8410 - 0v
When amps drop I test all the coils and voltage is unchanged so the F7000 stays at 13v's.
I adverted you, do NOT check L7410/20/30.
L7210/20 voltage could be good, but should b3e compared with good working board.
Do you note this voltage droping from 1V in few seconds?
You've forgot L8020.
Don't you get 1.2V at L7900?
ALWAYS check DC voltage at output pin of a coil.
