MacBook Pro 2017 13" will not turn on after screen replaced?
Leave the battery disconnected.
The board should turn on automatically, when charger is connected.
If not, press power button.
RicardoV
When I was testing the coils I had already removed the LB from the case so the battery has not been connected. I did have the charger plugged in when testing the coils but something definitely happened because amps are now only running at 0.02 to 0.04a.
I don't recommend you to spend more time with this board.
You did something wrong when swapped the screen panel.
Do not insist, as seems you already made more damage after that.
I hope you don't take this as an offense.
Just need someone with more experience to try and recover it (if still possible).
