MacBook Pro M4 Pro 2024 (A820-03400-5) – Keyboard not detected, all rails check out – Suspect UT102 (TCAL6416) internal VCC-VCP leakage
macfix_hh_25
Hi everyone,
i got a MacBook Pro M4 Pro 2024 (820-03400-5) with following problems:
Working with schematics for 820-02918 (M3 Pro)
as no schematics for 820-03400-5 are available yet. Most signal names and topology appear consistent.
Board background: Board came in with severe physical damage – bent chassis, bent keyboard and multiple sharp impacts on the display. Original symptoms: starting but black display, not starting with good known new display, dead keyboard, WiFi chip running hot+not working, no charging detected.
Resolved so far:
  • UL000 (WiFi/BT) was internally shorted on PP1V8_S2 (7.1Ω to GND, 1.79V holding stable, 90°C operating temperature, only the chip itself was hot – not the surrounding caps). Removed UL000 → PP1V8_S2 short cleared
  • New UL000 installed, properly unbound/bound LB Tools programmer
  • Display works with a new known-good display assembly.
  • Trackpad fully functional.
Remaining issue – internal keyboard does not work:
Tested with new known-good keyboard and with a separate complete chassis/keyboard assembly – same result. Confirmed not a cable, connector, or keyboard-side defect.
Measurements (all with board powered unless noted):
Measurement pointValueStatus
PP3V3_S2_HOLD_IPD @ CT1203.28V
PP1V85_S2_HOLD_KBD @ CT1131.83V
JT200 pin 2 (PP1V85_S2_HOLD_KBD)1.83V
JT200 pin 34 (PP3V3_AON_KBD_CONN)3.28V
UT101 RESET* @ CT1113.25V✓ HIGH (out of reset)
UT102 RESET* @ RT1203.25V✓ HIGH (out of reset)
I2C_KBD_SCL @ RT1233.28V✓ idle high
I2C_KBD_SDA @ RT1243.28V✓ idle high
IOXP1_INT_L @ RT1252.98VSlightly pulled
IOXP2_INT_L @ RT1122.98VSlightly pulled
IOXP2_ADDR1.83V
KBD_DRIVE_Y0 @ JT200 pin 100.00VNo scan activity
KBD_SENSE X6/X7/X9/X11 etc.1.81VPull-up idle state
Suspected root cause – UT102 internal VCC-VCP short:
The pin 23 that should carry IPD (~1.85V) on UT102 reads 3.28V instead.
Resistance measurements with board off:
  • CT122 pin 1 (PP1V85_S2_HOLD_KBD) to GND: 250Ω
  • CT120 pin 1 (PP3V3_S2_HOLD_IPD) to CT122 pin 1: 158Ω
A 158Ω path between the 3.3V VCC rail and the 1.85V VCP rail with the board off indicates an internal leakage inside UT102 between its VCC and VCP pins. Because UT108 (LP5907SNX-1.825) is an LDO and cannot sink current, this leakage pulls VCP up to VCC potential. Result: all GPIO I/O levels of UT102 swing at 3.3V instead of 1.8V, which the SoC's keyboard interface cannot communicate with.
This is consistent with internal die damage from the impact – everything passive measures correctly but the chip's internal level-shifting reference is corrupted.
Planned next step: Replace UT102. Before replacement, planning to verify UT101 doesn't have the same defect by measuring CT110 to CT113 resistance.
Questions for the forum:
  1. Has anyone seen this specific failure mode (VCC-VCP internal leakage on TCAL6416) on impact-damaged M-series boards or is it just a different rail /pin conncetion?
  2. Could it be that M4Pro has a different keyboard connector then M1- M3? (only tested with M1 Pro Keyboard as good known keyboard)
  3. Is my interpretation of the LDO not being able to sink current correct, or am I missing something obvious?
  4. Are there any other measurements I should take before committing to the UT102 replacement?
  5. On M4 Pro (820-03400-5) – has anyone confirmed whether the pin assignment for UT102 matches the M3 Pro reference schematics, or are there changes I should be aware of?
Open to any input. Thanks in advance.
Can you confirm if that is the correct boardview?
Some people complained on Internet thread where I downloaded.
macfix_hh_25
It's not 100% the same setup so boardview is slightly different to the A03400-05 I've got in the shop.
I got a genuine new keyboard for the M4 to test your theory. Unfortunately it's not solving the problem and the keyboard is still not working (recognize by the logicboard) and I am not able to type in any thing
macfix_hh_25
It's not 100% the same setup so boardview is slightly different to the A03400-05 I've got in the shop. But it helps in many ways to find information about the board.
macfix_hh_25
there is still an issue with the camera not detected. Could you give me readings from a good know board for JP400 Pin 29. It's 1,79V on my board but should by 5,11V regarding the boardview. RD964 (green marking), CD950 (blue marking) are nostuff on my board but I have a chip on the board, that is not shown in the boardview next to RD964. I marked it yellow.
I thought about bridging Pin 29 to Pin 30 to get 5.11V on both pins but something is telling me not to do it.
Could there be a difference in pin layout or 3401 board camera for -A and -5 boards? Doesn't really make sense to me.
I tested several good known camreas from A2442, A2779, A3112, A3401 on this board. All not working.
Also in system report, the camera is not detected.
Over all, is this an Hardware or Software issue?
Thanks for your help
Blue spot corresponds to RD964, not installed; is direct contact 1-2 (0 ohm).
The green spot is for UD950; current monitor not used.
Be aware, the boardview may be totally different and these components aren't the expected one.
There may be correct 1.8V, not 5V.
Is the blue spot trace connected to pin 29/JP400?
