Macbook Pro Retina 820-3332 Instant Death after powered USB plugged in. PLEASE HELP!
You have a problem with SMC_RESET_L; it should be steady 3.3V.
Remove R7000 and check it again.
If still bad, remove (clean at least) J6100.
Be sure R5028 is OK; remove it and test SMC_RESET_R_L,
Ig good, then change SMC.
J5100, sorry.
Are you sure only R5000 connected to pin 5 of U5010?
Check continuity from there to R7000.
R5028 is 0 ohm resistor, so may not be placed, if trace is OK.
cryptopher
Replaced R5000 and U5010 and now I have 3.4 on smc reset on pin 5 and R5000 but when I probe R7000 I still only get 1.6
SMC_RESET_L is generated through R5000, from 3V42.
And U5010 controls the delay time required by reset function.
"when I probe R7000 I still only get 1.6"
Do you mean SMC_RESET_L drops to 1.6V when solder R7000?
Change U7000 then.
Which pin of R7000 has 1.6V?
cryptopher
Never mind spoke too soon... computer keeps restarting.. I get log in screen sometimes but it goes half way and gets stuck
