MBA A2337 Freezing Behavior
mushr00m
AMR_RIGHT_OR_ND_1V8 = I didnt disamble the board at at all. Is there a way to check it without dissamble or the LEFT measurement already means something since its below 1.8v?
Just to let you know with the LID open and leaving the computer for 1 hour without usage when I use trackpad and keyboard its working fine.
I guess its related to closing the LID
" AMR_RIGHT_OR_ND_1V8 ="???
1.5V should be good enough.
Freezing problem is still present testing with JE900 disconnected?
mushr00m
I didnt disconnected JE900 I disconnected the other side of it on the small board with the audio jack (image attached)
The freezing problems looks like its gone.
mushr00m
How can I measure AMR_RIGHT_OR_ND_1V8 with JE900 connected and the board assembled? Is there a way? Looking at the schematics the only point would be RR201 which is on the back side of the assemble board.
The only option is dissamble everything? Is there a way to measure without dissamble?
Try to isolate its trace from JE900.
Left right sensor is sufficient, if machine works good without right one.
The pull-up resistor is on the MLB (RR201); no need to keep the sensor connected.
mushr00m
I did not understand. What do you mean by isolate the trace?
JE900 is below the board I didnt disconnect it on JE900
I disconnected it on the small board which have the audio jack and I am not sure the position of this trace on that small board since I only have schematic of the main logic board.
Yes machine works fine with the other side of JE900 disconnected
Yes RR201 is on the main board and also on the side that is NOT accessible with the board connected
mushr00m
I am thinking is easier and cheaper to cut off the trace somewhere.
Is it possible? If so how to do it on this board?
mushr00m
Can you explain me with more details detail what to do?
I kind of keep asking you, and you give me shallow information of what to do, usually a tiny sentence then I need to come here and make the almost the same question again.
I am deeply sorry to have less knowledge than you in this area and come here to ask you.
But that's how I repair some boards and it helps me make a living.
RR201 is by default connected to pin 1of UR200 according to the image
You must cut off the trace for AMR_RIGHT_OR_ND_1V8, maintaining RR201 connected to UR200.
Do NOT cut between RR201 and UR200!
So find a convenient point to do this.
Just need to interrupt the connection with JE900.
mushr00m
PERFECT! I understood 100%
Since you have more knowledge than me with newer boards
Do you have a suggestion for this convenient point? Lifting the PIN 10 on JE900 would be convenient and safe? Is there a better option?
Best option, cut the trace.
Do not damage the connector; in case you decide to change AMR sensor in the future.
I don't have the board in front, to follow that trace...
mushr00m
OK
Board out of the case
We have a TP before going to the JE900 on the board itself.
Should I use the knife blade and CUT the surface of it as I am pointing in the picture attached?
A bit afraid to damage anything
A small cut would work?
There is good to cut the small trace.
Be aware, do not damage that "test point"; there is where the trace goes inside the MLB.
Is not a pure test point.
Not a big problem however, if will not replace the affected AMR sensor in the future.
mushr00m
Done.
Cut a bit of it and now it seems to be 100% working
Just noticed if I close the lid without locking the screen and open again after a few minutes it still UNLOCKED.
Did the RIGHT AMR sensor would be responsible for automatically locking the machine when closing the lid?
